Hiện kết quả từ 1 tới 10 của 13
Chủ đề ::: [HACK] Guardian Cross v2.0.0 (Post #7)
    05-05-2010 3:46 pm
    Mặc định [HACK] Guardian Cross v2.0.0 (Post #7)
    Use these h@cks at your own risk. Do not use them on your main account. Create a h@ck account to do the h@cking.
    h@ck cho v 2.0.0:
    http://heaveniphone.com/threads/125797-h@ck-guardian-cross-v2-0-0-post-6.html?p=1101347#post1101347
    Download: (Updated on 5/14)
    GCh@cks.zip contains the following files:
    - GCHunt.dylib, and hunt.cfg
    - GCData.dylib, and data.cfg
    - GCStones.dylib, and stones.cfg
    - GCBattle.dylib
    HIDE: OFF:
    http://speedy.sh/fW56k/GCh@cks.zip
    http://www.sendspace.com/file/eydrss
    Installation:
    - Make sure you have Mobile Substrate installed from Cydia
    - Put the h@cks you want to /Library/MobileSubstrate/DynamicLibraries
    - For GCHunt, put hunt.cfg in /var/mobile/Applications/(GC App)/Documents (see usage section)
    - For GCData, put data.cfg in /var/mobile/Applications/(GC App)/Documents (see usage section)
    - For GCStones, put stones.cfg in /var/mobile/Applications/(GC App)/Documents (see usage section)
    Usage:
    1. GCHunt:
    modify hunt.cfg to do the following:
    - Create Cards (see below for more information)
    - During hunting, the monsters will move very slowly
    - Oneshot kill all monsters (except Sea snakes in Ocean which is now a 2 hit kill )
    - Time extension for all monster kills
    - Can continue to shoot even though you have no ammo (no reloads)
    - All cards can be traded (Even if bound)
    Creating Cards:
    (Warning! Do not use this on your main account)
    - Put the Card ID, Level and Type of what you want in hunt.cfg
    - If you would like to get the card via hunting, set changeCardDuringHunt to true
    (Make sure you only hunt what is available in the area, and only hunt 1 card at once per hunt)
    - If you would like to change 1* cards at start up of the game into the Card ID you want, set changeCardOnLoad to true
    (Make sure you clean up the cards afterwards via rebirth or feeding if you use this method)
    2. GCData:
    Modify data.cfg to what you want to change. Here are the variables that you can change.
    (Note - these are not permanent until you perform an action that triggers a change. For example, if you set your PlayerLevel to 40, it won't be permanent until you level up)
    - PlayerLevel - Your character level. Note that this is not permanent until you level up.
    - BattlePotion - Number of potions
    - PremiumTicket - Special Tickets
    - GameMoney - Your GP
    - FriendPoint - Your Friend Points (Warning, this may get you banned?)
    - BattleTicket - Your BP (Probably safer to use Potions)
    - NormalTicket - Normal hunting tickets
    - ColosseumTicket - Coli tickets (do not abuse this or you may get banned)
    Note - if you add // before a line, the line is disabled.
    3. GCStones:
    Modify stones.cfg to:
    - Convert coli stones to whatever you want in the stones.cfg file
    - Specify how many stones in your inventory for each stone. The total amount of stones is not locked and will go down so don't let them go to zero
    See the following link to see the ID values of each stone:
    http://goo.gl/fMTVz
    4. GCBattle:
    Makes all map battles skippable
    FAQ
    1. What is (insert card here)'s card ID?
    See
    http://goo.gl/fMTVz
    Look in iFile - go to /var/mobile/Applications/(GC App)/Library/Caches/dlcaches for new cards
    2. How do I instant level up to lv40?
    Set PlayerLevel to 40, PlayerExp to 300 (or whatever it takes to level up at lv40), then fight a guardian in the field
    3. Are the cards created legit?
    No (especially when using the 1* to 5* conversion method). But if you rebirth the cards immediately and send them out, they should be fine.
    4. The stats of the cards are wrong! They have "cool" type stats even though they're Aces
    Just restart the game and the stats will be fine again.
    5. I can't download the files, I just get a blank page
    Try another browser.
    6. Can I have your source code?
    If it's more than 10 lines, most likely the answer is no. I don't mind answering your PMs about h@cking in general though.
    7. Can you build me a h@ck file with only these things?
    I'll consider it if it's a good idea, but otherwise no.
    8. How do I multi-account?
    Please see:
    vip-tutorials-f15/guardian-cross-tutorial-getting-backed-from-the-banhammer-t10244.html
    vip-tutorials-f15/make-multiple-gc-accounts-on-one-device-t12736.html
    To be added...
    Enjoy!
    Lần sửa cuối bởi [Ars]Giang™; 02-07-2013 lúc 10:28 AM
  2. Trong số 8 thành viên sau đây đã cảm ơn yeunhieu cho bài viết này:
    hitoko (23-05-2013), Inca (06-05-2013), inuzori (25-05-2013), nch93 (02-07-2013), rainbow27091998 (12-11-2013), thienminh1602 (05-09-2013), tjeudaotu (09-06-2013), TronAtula (08-06-2013)
    10-07-2011 4:52 pm
    Xin hỏi có ai h@ck được chưa ? nếu được có thể hướng dẫn chi tiết dùm (thank trước), mình đã làm như cách trên nhưng vào game không thấy có tác dụng
    Avatar của hitoko
    hitoko đang ẩn Thành viên Tài sản: Iphone 3GS lock iOS hiện tại: 5.0.1 (9A405) custom Baseband: 05.12.01 SHSH: không biết xem ai bít Pm inbox dùm :D
    01-08-2011 10:15 am
    Đà Lạt
    Good h@ck ... thank....!
    Lần sửa cuối bởi hitoko; 23-05-2013 lúc 12:58 PM
    17-07-2011 4:51 pm
    Cám ơn nhiều, h@ck này bên kia phải có vip mới thấy dc.
    14-11-2012 2:04 am
    bác nào giúp em cái vụ multi account với ạ
    22-06-2013 4:03 pm
    bac nao giup em h@ck hunt voi
    21-06-2013 6:42 pm
    h@ck Guardian Cross 2.0.0:
    Nên h@ck bằng account phụ, ko nên h@ck trên acc chính.
    h@ck 1.3.0 vẫn dùng dc trừ GC Stone (dùng GC99Stones bên dưới, tải h@ck v 1.3.0 ở post #1).
    Chú ý phải cẩn thận vì dễ bị banned, chỉ nên gửi 1 card 1 ngày.
    Use these h@cks at your own risk. Do not use them on your main account. Create a h@ck account to do the h@cking. h@ck for v 1.3.0 still works for 2.0.0 except GCStones (use GC99Stones thay thế, download h@ck v 1.3.0 in post#1).
    Be very careful or you'll be banned, send one card a day, no more than 2 a day, that's pushing it.
    h@ck GC99Stones:
    http://www.mediafire.com/download/yj...GC99Stones.zip
    you can try this if you want
    - put the GC99Stones.dylib into "mobile substrate > dynamic library"
    - open your GC and use 1pcs of the stone you want to change, then remove the GC99Stones.dylib and it will change to 99
    - if you dont use 1pcs the stone you want to change, when you remove the GC99Stones.dylib, the stone will return to normal
    - this is for GC 2.0
    - still the same word, GC 2.0 is still dangerous.... using h@ck is not really a good idea >_<
    Update 1 cách cheat mới:
    On monday I created an Ace Puca card with these steps.
    1. I Hunted with GCHunt and a NHT in my level 3 h@ck account I hunted for 15 cards making sure i caught at least 8 1* cards. I only caught 15 cause I didn't want to get banned for catching too many if they watch that now.
    2. Next I went to sell extra cards. I kept an Ace 1* and 7 random 1* cards and sold rest so I had a total of 8 cards.
    3. I quit GC and edited my hunt.cfg to look like this:
    // Card ID you want - http://goo.gl/fMTVz
    cardID = 40211
    // Level of the card you want
    cardLevel = 60
    // 0 - Cool, 1 - Powerful, 2 - Fast, 3 - Brave, 4 - Intelligent, 5 - Chaotic, 6 - Sexy, 7 - Ace
    //cardType = 7
    // Set to true if you want to convert 1* cards to the Card ID above
    changeCardOnLoad = true
    // Set to true if you want to get the Card ID above during hunting
    changeCardDuringHunt = false
    // Set to true if you want to get +10 sec after every monster during hunting
    timeBonusDuringHunt = false
    4. Started up GC and Rebirthed Puca card I was creating then used the 6 left over 5* cards to get card to level 70.
    5. Next I immediately gifted card to my level 3 storage account #1.
    6. Logged into storage account #1 accepted gift and then gifted to level 3 storage account #2.
    7. Logged into storage account #2 and accepted gift and then gifted to a level 40 account that I have a bunch of stones in.
    8. Logged into stone account and fully stoned card where it has sat since Monday.
    9. Just a few min ago I gifted it to storage account #2 and then back to sone account without any problems.
    I have used this method many times and have never had any cards go illicit at any time. The only time i got an illicit card was when i changed the type to ace. Since then I have always hunted for ace 1* cards. If I don't catch an Ace 1* card I sell all the 1* cards and start over.
    I haven't gifted to main account yet but plan to try on Monday
    Hope this helps.
    Lần sửa cuối bởi LeechHackVip2; 02-07-2013 lúc 10:29 AM
  9. Các thành viên đã cảm ơn LeechHackVip2 cho bài viết này:
    lsadfor9 (16-07-2013)
  10. #8
    nch93 đang ẩn Thành Viên Tài sản: 6Plus-ipad4 iOS hiện tại: 8.3-7.1.2 Baseband: WORLD SHSH: SHSH
    11-03-2012 5:23 pm
    Bách Khoa-Hà Nội
    Quote Nguyên văn bởi Leechh@ckVip2 Xem bài viết
    h@ck GC99Stones:
    Hope this helps.
    cái này tạo account phụ kiểu gì vậy bạn. trên có link hd nhưng có vào được link đâu
    21-06-2013 6:42 pm
    Quote Nguyên văn bởi nch93 Xem bài viết
    Tự mò nha, iAPFree 4.0.1 ko có fake MAC iP, kiếm bản cũ mà dùng(tìm trong diễn đàn), mình ko chịu trách nhiệm nếu máy bị ăn táo:
    You need on your device:
    - Guardian Cross App
    - iFile
    - Installous or AppCake
    - IAPFree or Terminal
    - UDIDFaker
    How to:
    -From iFile, find the directory /var/mobile/Applications
    -Go into Applications find the application called GC.
    -If you are unable to see names for the application and there are only codes, press the setting button on your bottom left hand corner of the ifile, then press File Manager, then under "Application Name" turn it on.
    -Ok now you should be able to see the app GC. Go into the app folder, you should see alot folders/file. Press edit, select "DoD En.app" and "iTunesArtwork", then press the copy button at the bottom right of your iFile. Copy/link the two files you have selected.
    Ok then press Done.
    -For Installous: go back to the /var/mobile, you should see Documents, go into Documents>Installous >Downloads.
    -For AppCake: go back to the /var/mobile/Documents /Downloads.
    -Now press Edit, then click the "+" button at the bottom left hand corner of the iFile.
    -Create a new Folder with Name : "App Duplicate", then press Done.
    -Now you are in the Downloads directory, you should see the "App Duplicate" Folder, go into the folder, then press Edit again, create a Folder and name it "Payload" remember the Payload must be Caps "P' and followed by ayload - 'Payload'
    -Now go into Payload, paste the 2 files you have copied earlier "DoD En.app" and "iTunesArtwork". Then press edit, select the iTunesArtwork, then press the cut button at the bottom right had corner of ifile. Get out of Payload folder and go back to App duplicate folder, Edit> paste the iTunesArtwork file here. So now in your screen, you should see Payload Folder, and below it is the iTunesArtwork file.
    -Now go back to Payload, go in DoD En.app folder. Wait for it to load, it should lag awhile. After you go in follow the video, search for the file called "Info.plist", click on the info.plist and select Property List Viewer. You should see CFBundleDisplayName. Change the value to "GC2". Then next below it, you should see CFBundleIdentifier, add random values behind the address. Orginal value:
    com.square-enix.guardiancrossww, you may add asd behind the address : "com.square-enix.guardiancrosswwasd", after you are done, get out and press Done.
    -Go back to the App duplicate folder, where you see Payload and iTunesArtwork, press edit, select both of them and zip both of the file. You can zip it by pressing the bottom left 2nd button. Name the Zip File GC2, wait for it zip finish, it should take a while.
    -Next after u zipped the file you should see a folder apear GC2.zip, rename the folder by pressing the blue right arrow next to it, and rename it to GC2.ipa.
    -Now you can go off your iFile.
    -Before installing GC2 with Installous/AppCake you have to change your mac address via iAPFree or Terminal!!! Otherwise you only clone the app with your current account!
    -Go to your Installous/AppCake, download section, install the GC2.ipa file, you just made, it should take a while for the app to install.
    After u install, you should see a app GC2 appear. Now you got App : "GC" and "GC2", u can make GC3, GC4, GC5 and so on, by repeating the steps. (Starting with the step with this sign )
    -Fake your UDID of every account using UDIDFaker
    -enjoy
  12. Các thành viên đã cảm ơn LeechHackVip2 cho bài viết này:
    nch93 (03-07-2013)
  13. #10
    09-07-2013 8:17 pm
    Now,I have a big problem. I was banned in GC2.0(Int.), Therefore, I change to GC2.1(Jap). But Most of the cr@cks can use except the amount of the premium ticket in the data.cfg. It have no use. Could you help solve this problem?
    thank you very much!
