Trang 5/6 ĐầuĐầu ... 3456 CuốiCuối
Hiện kết quả từ 41 tới 50 của 56
Chủ đề ::: iMazing v2.6.3 for MAC - Quản lý iDevice.
  1. #41
    Avatar của AnhPhe-VNPT
    AnhPhe-VNPT đang ẩn What doesn't kill me makes me stronger...! Tài sản: All iDevice! New iPX Black, Apple Watch Series 2. iOS hiện tại: iOS = iPX v11.4-MacBook Pro v10.13.5-watchOS v4.3.1. Baseband: All Baseband. SHSH: No SHSH.
    06-05-2009 6:49 pm
    Vietnam Posts and Telecommunications Group.
    iMazing v2.2.6
    WHAT’S NEW
    Version 2.2.6:
    iOS 10.3 compatibility
    iMazing is now fully compatible with iOS 10.3
    Transfer photos to device and manage albums
    Create and delete albums
    Add photos in albums
    Remove photos from albums
    Books management (iBooks)
    Transfer .pdf documents to iBooks
    Transfer .epub books to iBooks
    Remove books and PDFs
    Download and update iOS
    Download and install latest available version from Apple servers
    Install .ipsw image file manually
    Handle device recovery and DFU modes
    Exit recovery mode
    Restore a backup, new options:
    Erase device before restore
    Update iOS automatically
    Choose new target device name
    Automatic device activation
    Activate device automatically via the computer's internet connection
    Doesn't require anymore to configure a Wi-Fi network in the device Setup Assistant
    Device and computer pairing
    Remove pairing without connecting the device to computer
    Remove all pairing records from computer (available in iMazing's preferences)
    Prevent iTunes and Photos from launching automatically
    Prevent iTunes from launching when connecting a device
    Prevent Photos from launching when connecting a device (Mac)
    Prevent iTunes from automatically backup an iOS device
    New battery info
    Battery Instant Amperage
    Battery At Warn Level
    Battery At Critical Level
    Battery Model
    Battery Serial Number
    Battery Manufacturer
    Battery Manufacture Date
    Battery Voltage
    Battery Amperage
    Battery Avg. Temperature
    Battery Min. Temperature
    Battery Max. Temperature
    Battery Max. Charge
    Battery Max. Discharge
    Bug Fixes and Improvements
    Fixed some rare crashes when restoring an .imazingapp file
    Fixed other rare crashes
    REQUIREMENTS
    OS X 10.7 or later, 64-bit processor.
    https://www.macbed.com/download/37398.html
    .............. ==> Nhận tư vấn lắp đặt, bảo trì Internet: Cáp Quang VNPT - Cần Thơ.<==...................
    Khách hàng liên hệ: 0919.076.076 - 0913.30.04.76 - 0945.30.04.76 - 0889.30.04.76 - 01217.30.04.76
  2. #42
    06-05-2009 6:49 pm
    iMazing v2.2.7
    Manage your iPhone. Your way.
    Get a trusted software to transfer and save your music, messages, files and data. Safely back up any iPhone, iPad or iPod touch. Powerful and user-friendly, iMazing is simply the best iOS device manager for Mac and PC.
    Go beyond iTunes. Get iMazing.
    Compatibility: macOS 10.10 or later, 64-bit processor
    Updated: Jun 7, 2017
    Version: 2.2.7
    Languages: Multi
    Seller: DigiDNA
    http://alfafile.net/file/xRNS
    http://ul.to/fk0jat0j
    http://rg.to/file/7fbfb34174f1c85a0b6ec344c476258a/
  3. #43
    06-05-2009 6:49 pm
    iMazing v2.3.0
    WHAT’S NEW
    Version 2.3.0:
    New iPad Pro info and icons:
    10.5-inch
    12.9-inch
    REQUIREMENTS
    https://www.macbed.com/download/39534.html
  4. #44
    06-05-2009 6:49 pm
    iMazing v2.3.3
    What's New Version 2.3.3
    Fixes in iMazing 2.3.3 (7847)Fixed a regression where importing an .imazingapp file in an editable backup was crashing iMazingFixed automatic backup's timeframe option, it is now working properly - many thanks to Moses, Anthony and Greg for their help Other minor bug fixes and stability improvementsNewIntegrated new iOS 11 iconsAdded power assertions to prevent computer sleep from interrupting backupsBetter handling of large backups to an external driveDevices are now always backed up before updating or reinstalling iOSBetter handling of iOS reinstallation on multiple devices simultaneouslyReinstall iOS: Added warning before iMazing puts the device in Recovery ModeFixesApple TV no longer displayed in iMazing Mini since tvOS does not allow backupsFixed crash when adding backup folderFixed rare case where a ‘Backup Successful’ notification was erroneously displayed (iMazing Mini)Localisation: fixed french spelling mistake of ‘Diagnostics’ (Thank you Serge!)Minor stability fixes.
    https://www.macappdownload.com/?p=2181&apps=download
    https://depositfiles.com/files/cflskvf90
  5. #45
    06-05-2009 6:49 pm
    iMazing v2.4.0
    What's New Version 2.4.0
    iMazing and iMazing Mini
    Backups: iMazing and iMazing Mini will now attempt to automatically mount network drives if they are active backup locations.
    Device Info: Exporting device info now includes paths of apps, including GUID.
    http://uploaded.net/file/oxcsmb4j
  6. Các thành viên đã cảm ơn AnhPhe-VNPT cho bài viết này:
    haipvg (05-09-2017)
  7. #46
    06-05-2009 6:49 pm
    iMazing v2.4.1
    Version: 2.4.1
    Languages: Multi
    Seller: DigiDNA.
    http://ul.to/i2ocivby
    https://rapidgator.net/file/ff5dbf176405bc19328ddbc53425e7b1
  8. #47
    06-05-2009 6:49 pm
    iMazing v2.4.2
    What's New Version 2.4.2
    • Backups: iMazing and iMazing Mini will now attempt to automatically mount network drives if they are active backup locations.
    • Device Info: Exporting device info now includes paths of apps, including GUID.
  9. #48
    06-05-2009 6:49 pm
    iMazing v2.4.3
    What's New Version 2.4.3
    Important: fixed a regression which could block backups at the ‘Preparing backup’ stage.
    Fixed export of filtered photos in HEIC format.
    Other minor stability improvements.
  10. #49
    06-05-2009 6:49 pm
    iMazing v2.5.0
    Fixes in version 2.5.0 (8216)
    • Fixed an issue where apps could be not installed when restoring a backup. Make sure to do a new backup if you were experiencing this issue.
  11. #50
    06-05-2009 6:49 pm
    iMazing v2.5.1
    What's New Version 2.5.1
    iPhone X
    • Support for new resolution in iMazing's UI
    • Minor compatibility adjustments
