Trang 1/5 123 ... CuốiCuối
Hiện kết quả từ 1 tới 10 của 44
Chủ đề ::: TeamViewer Pro HD for Remote Control v8.0.9880 - Điều khiển PC từ thông qua Wifi [05/12/2012]
    Avatar của AnhPhe™[076]
    AnhPhe™[076] đang online Administrator Tài sản: iP4s, iP5, iPad 2, The new iPad.....! iOS hiện tại: FW = 5.1.1, 6.0.1, 6.0.2....! Baseband: 4.12.01 - 1.01.00 - ......! SHSH: 4.3.3, 4.3.5, 5.0.1, 5.1, 5.1.1, 6.0.1....
    Trung Tâm Viễn Thông Cần Thơ.
    Mặc định TeamViewer Pro HD for Remote Control v8.0.9880 - Điều khiển PC từ thông qua Wifi [05/12/2012]
    TeamViewer Pro HD v6.0.9302 for iPad
    • $139.99
    • Category: Productivity
    • Updated: Sep 27, 2011
    • Version: 6.0.9302
    • Size: 14.0 MB
    • Languages: English, Danish, Dutch, Finnish, French, German, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Russian, Spanish, Swedish, Turkish
    • Seller: TeamViewer GmbH
    • © TeamViewer GmbH
    Rated 4+
    Requirements: Compatible with iPad. Requires iOS 3.2 or later
    Customer Ratings
    We have not received enough ratings to display an average for the current version of this application.
    Description
    TeamViewer Pro HD provides easy, fast and secure remote access to Windows, Mac and Linux systems.
    TeamViewer is already used on more than 100,000,000 computers worldwide and with the TeamViewer Pro HD app for iPad you are able to:
    - On the fly support your clients and colleagues
    - Have access to your office desktop with all of its documents and installed applications
    - Remotely administer unattended computers (e.g. servers)
    - Transfer files from a remote pc to your iPad and vice versa
    Features:
    - Remotely access unattended computers
    - Conveniently control remote computers using the iPad multi-touch gestures: left click, right click, drag & drop, scroll wheel, zoom, change monitor
    - Complete keyboard control incl. special keys such as Ctrl, Alt, Windows®
    - Meets highest security standards: 256 Bit AES Session Encoding, 1024 Bit RSA Key Exchange
    - Effortlessly access computers behind firewalls and proxy servers
    - Remotely reboot the computer
    - Automatically adjust the screen resolution of the remote computer
    - Overview of computers that are online via the integrated Partner list
    License:
    TeamViewer Pro HD provides access to any number of remote computers for which you do not have to purchase any additional licenses. Even installing TeamViewer on unattended computers does not incur any additional cost!
    Quick guide
    1. Install and start TeamViewer Pro HD from the App Store.
    2. Install and start TeamViewer on your computer (www.teamviewer.com).
    3. Enter your computer’s TeamViewer ID and password directly in the TeamViewer interface on your iPad to connect.
    Note: Additional quick guides for different applications can be found at www.teamviewer.com/ipad
    TeamViewer Web SiteTeamViewer Pro HD Support
    What's New in Version 6.0.9302
    - Introduced App tutorial
    - Improved translations
    - Minor improvements
    http://www.mediafire.com/?ebr85716co7v33f
    Đã có trên Hipstore!
    No Spam! Click "Thanks" is enough!
  2. Trong số 11 thành viên sau đây đã cảm ơn AnhPhe™[076] cho bài viết này:
    dark_knight_141002 (29-04-2012), DoanHuy † (28-09-2011), ghost_rider (25-12-2012), hdang58 (17-03-2013), kaka8282 (04-03-2012), kani (28-09-2011), manowar112 (26-01-2013), momokan (28-09-2011), nguyentrong (06-01-2012), thailoc (23-02-2012), thithu (26-04-2012)
    Avatar của kani
    kani đang ẩn Thành viên nhiệt tình Tài sản: ipad 3 3g iOS hiện tại: 5.1.1 và 6.0 SHSH: 00000
    Oct 2009
    Hà Nội <-> Mộc Châu - Sơn La
    e vừa cài xong,dùng thấy ổn a ạ
    Tiền thì a không thiếu,chủ yếu a bảo e phải ngoan,ngoan thì cái gì cũng có
    TeamViewer Pro HD v6.0.9309 for iPad
    What's new in Version 6.0.9309
    Minor improvements on iOS5
    http://fileape.com/dl/D3HvdvakXQLAj6VG
    http://www.filedude.com/download/01qwtiXRas9568b9b071
    Avatar của hungkool92
    hungkool92 đang online Thành viên tích cực Tài sản: iphone 4 - ipad 2 iOS hiện tại: 5.1.1
    Mar 2011
    dùng kiểu nào vậy
    TeamViewer Pro HD v6.0.9348 for iPad
    What's New in Version 6.0.9348
    Updated communication protocol to support TeamViewer Version 7.
    http://store.heaveniphone.com/2011/1...er-pro-hd.html
    TeamViewer Pro HD v7.0.9391 for iPad
    • $139.99
    • Updated: Dec 07, 2011
    • Version: 7.0.9391
    • Size: 19.7 MB
    • © TeamViewer GmbH
    What's New in Version 7.0.9391
    - Support for iOS5 split keyboard
    - Enhanced support for asian keyboards in iOS5
    - Improved remote cursor accuracy
    TeamViewer Pro HD v7.0.9393 for iPad
    • $139.99
    What's New in Version 7.0.9393
    - Fixed connection problems and improved stability
  9. Các thành viên đã cảm ơn AnhPhe™[076] cho bài viết này:
    hieustar (10-02-2012)
  10. #8
    TeamViewer Pro HD v7.0.9413 for iPad
    What's New in Version 7.0.9413
    - Fixed problem with Asian characters
    - Various minor fixes and improvements
    http://heaveniphone.com/productivity...o-tai-hip.html
  11. Trong số 2 thành viên sau đây đã cảm ơn AnhPhe™[076] cho bài viết này:
    rgx120 (16-11-2012), thevinhkg341 (05-03-2012)
  12. #9
    tuankiet65 đang ẩn Thành viên tích cực Tài sản: iPad 2 iOS hiện tại: 5.1.1 Baseband: Quan tâm làm gì =)) SHSH: Đủ loại từ 5 trở đi
    Đà Nẵng
    app gì mà tới 140$ vậy anh. chắc kiểu này sạt nghiệp mất
  13. #10
    Jan 2012
    cảm ơn nhìu
    dù chưa bik cái này xài sao =.=''
