ios5 (27-04-2012)
chia buồn cũng chủ topic đã test ko đc trên 3gs T_T
Sao không đc nhỉ, sáng nay mình vừa nhận đc email
We recently received your request for the unlock code on the following device:
EMAIL: nguyenthingocha1907@gmail.com
CASE: CM20120416_39443399
MOBILE: 0000000000
MANUFACTURER: Apple
MODEL: iPhone_4
IMEI: 012*********333
Thank you for contacting AT&T Customer Care about unlocking your iPhone. We have reviewed your request and confirmed that you are eligible to have the requested iPhone unlocked.
To complete the unlock, simply:
1. Open iTunes on your Mac or PC and verify that you have internet connectivity.
2. Connect your iPhone using the dock connector to USB cable that came with your iPhone.
3. Backup and restore your iPhone using iTunes .
For information on backup and restore, please visit http://support.apple.com/kb/HT1414.
4. After restoring, your iPhone will be unlocked.
Additional information on unlocking can be found at http://support.apple.com/kb/TS3198.
For questions regarding AT&T’s wireless service and iPhone, please visit the Phone/Device Learning Center. We thank you for your continued business and look forward to providing you with the best customer service.
Thank you for contacting AT&T Mobility. We appreciate your business.
This e-mail and any files transmitted with it are the property of AT&T are confidential, and are intended solely for the use of the individual or entity to which this e-mail is addressed. If you are not one of the named recipient(s) or otherwise have reason to believe that you have received this message in error, please notify the sender at (1-800-331-0500) and delete this message immediately from your computer. Any other use, retention, dissemination, forwarding, printing, or copying of this e-mail is strictly prohibited. RH7776
Vậy là mình deactive mà vẫn không đc, nên mình thử cách này, thành công 100% ngay lần đầu làm
Các bạn làm theo thứ tự tháo sim ra, Vào setting, cài đặt chung, chọn đặt lại, chọn ĐẶT LẠI TẤT CẢ CÀI ĐẶT VPN (dòng đầu)
đợi nó cài đặt xong rồi next next, cắm vào itunes sẽ nhận sóng, mình đã làm và thành công 100%, máy có cài cydia nhé
Lần sửa cuối bởi Thế Thì Thôi; 20-04-2012 lúc 07:22 AM
ios5 (27-04-2012)
Dear AT & T
I am very happy to receiving reports that AT & T will unlock for iphone 4. When I send mail to unlock and get a response, I am very sad. Mail contents are as follows:
"The unlock code for this device is unavailable due to security restrictions based on the device's history."
I bought from a sales network in Vietnam, I do not know how to unlock as guidelines for my case.
As in Vietnam do not have AT & T so I can come and present my case.
Can you help me ? what should I do ?
I hope that you will help me, so happy to receive your help.
My IMEI: xxxxxx
Serial: xxxxxxxx
Again thank you for your interest in my problem.
Wish all good things come to you.
Gửi chủ thớt , mình cũng bị như bạn nhưng mình đã gửi lại 1 mail khác với nội dung như vậy và đã đc unlock , bạn tham khảo và chúc bạn thành công .
ios5 (27-04-2012)
Bạn ơi giúp mình với. mình active bằng resnow nhưng không được. iphone của mình bây giờ không vào được màn hình chính bạn à.
Của mình chỉ cần bỏ sim vảo lả nó tự active ah, ko biết có bị gì ko ta
máy active nước ngoài không jaibreak vẫn vào màng hình home mà
ios5 (27-04-2012)
ios5 (27-04-2012)
